B C220/B 223 Scan to mail refference ID
  • CKiiza
    • Feb 2010
    • 77
    On these machines when in User Authentication mode, by default, the scan mail is sent from the logged in
    user's mail ID. Is it possible to set it to show the sender's mail as the machine's mail ID and not the
    logged in user email ID?
  • pepper38_cnd
    Field Service Manager
    • Aug 2005
    • 1075
    Re: B C220/B 223 Scan to mail refference ID
    Simply removing their email address from the user details will do but you loose the "Scan To Me" function. You could also set up Public User with the right to scan then no login would be required to scan, but scans would not be tracked. Most people do not track scans anyway.
    Now into Ip TV KODI Boxes
    • CKiiza
      • Feb 2010
      • 77
      That precisely is the problem, it displays xxxx@xxx.com as the mail from which scan mail is being sent.
      Is there a way to make it display the machines' email ID as the sender ID instead of xxxx@xxx.com
      • dallas
        • Jun 2008
        • 115
        Change to Admin E-Mail Address
