Bizhub C451
  • BFtech
    • Dec 2011
    • 19
    [Error Code] Bizhub C451
    I have a C451 Konica Minota machine with a sc-102 code...can someone give me details of this code and possible remedy? Thanks
  • JustManuals
    • Jan 2006
    • 9838
    Re: Bizhub C451
    Paul@justmanuals.com
    • RRodgers
      • Jun 2009
      • 1947
      Re: Bizhub C451
      Tech mode tells you what the code means, but if you not a tech... I'd recommend calling one.
      • emujo
        • Jun 2009
        • 3009
        Re: Bizhub C451
        Double check your error code..there is no SC-102 listed in the service manual..failure codes should be something like:
        C3208
        J8114
        p-7
        L-4
        Emujo
        • BFtech
          • Dec 2011
          • 19
          Re: Bizhub C451
          thanks emujo..the customer said that the code was cs 102..thats all I got.
          • BFtech
            • Dec 2011
            • 19
            Re: Bizhub C451
            RRodgers thanks for your help.......NOT...
            was not able to be in front of MCP to check..but thanks anyway
            • RRodgers
              • Jun 2009
              • 1947
              Re: Bizhub C451
              Maybe I helped someone else besides you.
              • BFtech
                • Dec 2011
                • 19
                Re: Bizhub C451
                First post on this issue..guess your not gonna help////////someone will
                • minimerlin
                  • 851
                  Re: Bizhub C451
                  If you could ask the customer to check the code! Maybe somebody could help...but the info you have given does not point to any listed codes.
                  Please do not PM me without asking first.
                  • emujo
                    • Jun 2009
                    • 3009
                    Re: Bizhub C451
                    BF...before you start complaining, at least get the correct code...I can assure you, no one can help with a code that doesn't make sense..and BTW he's correct, if you're not a tech, you probably won't be able to solve the issue..parts/firmware aren't free. Someone is trying to help you..if you start blasting everyone, the help will stop. Emujo
                    • BFtech
                      • Dec 2011
                      • 19
                      Re: Bizhub C451
                      no comlpaints here. looks to me like you all are busting me and asking if i am a tech.. profile last time I looked said I was a tech for 15 years...just thought I could get a quick answer when I posted and bam fingers start getting pointed and blastin off at if I am a tech...SORRY for your time. Emujo chimed in when I said nothing to you about your response in fact I thanked you for an effort. Oh well Kick a man when hes down. I see how it is.
                      • blaze2000
                        • Sep 2010
                        • 232
                        Re: Bizhub C451
                        perhaps c1102? w/ fs526, check. your main tray lift.
                        • RRodgers
                          • Jun 2009
                          • 1947
                          Re: Bizhub C451
                          I forgot to add, (this should help some out there I'm sure) on some of the older machines, if the machine has an error code and you can't find the code listed when you go into tech mode then that means it's an accessory error (ie finisher, paper tray)
                          Just a little something to help anyone out there that might be reading this thread.
