Konika Minolta BizHub 163 - Error Code? M2
  • Smiley27
    • Apr 2011
    • 160
    [Error Code] Konika Minolta BizHub 163 - Error Code? M2
    Machine gives me this error message, what does it mean ?
    Thanks.
    Found out ! Its maintenance, but how do clear this message? Friend of mine mentioned ''dataclear'' but I dont know...
  • Gaffers01
    • May 2011
    • 335
    M2
    • Smiley27
      • Apr 2011
      • 160
      Re: Konika Minolta BizHub 163 - Error Code? M2
      I am fine with that, but , how to enter service mode ? Someone mentioned turning machine off/on and hold STOP.. Whats up with that?
      Originally posted by Gaffers01
      M2
      • Gaffers01
        • May 2011
        • 335
        press the Utility button,
        then Stop → 0 → 0 → Stop → 0 → 1
        then scroll to Clear Data, and then Supplies Data and clear.
        You must be aware that clearing this counter clears the drum, developer and other counters.
        Which are very important for copy quality, and not replacing them may cause more harm than good.
        • Smiley27
          • Apr 2011
          • 160
          Error is cleared. Machine works now, I am suppost to replace drum since it made 40000, but drum is fine...
          If I want machine to make another ''?????'' what counters do need to be clear? I already deleted ''Supplies Counter'' , but I am afraid machine will stop again if another counter reaches its limit..
          So I got :
          MEMORY COUNTER
          TOTAL COUNTER
          PM COUNTER
          MAINTENANCE COUNTER
          SUPPLIES COUNTER ( CLEARED )
          APPLICATION COUNTER
          SCAN COUNTER
          MISFED COUNTER
          PAPER SIZE COUNTER
          Also, should I set IU life stop mode to : continue ( its on STOP now )
          Also,give me a clue what exactly ''developer'' is? drum?
          • minimerlin
            • 851
            So I got :
            MEMORY COUNTER
            TOTAL COUNTER
            PM COUNTER
            MAINTENANCE COUNTER
            APPLICATION COUNTER
            SCAN COUNTER
            MISFED COUNTER
            PAPER SIZE COUNTER
            Be prepared for an error code very soon! If you do not run atdc setup after you clear the supplies counter ..you will get the error!
            Please do not PM me without asking first.
            • EarthKmTech
              Step aside, noob
              • May 2009
              • 2139
              thats the only thing that should of been changed.
              the IU counter shouldn't of been reset without actually changing the parts.
              the drum will usually last up-to 60k before it fails but don't count on it.
              • Smiley27
                • Apr 2011
                • 160
                So,how do I run it?''atdc'' and,what that is?
                • Smiley27
                  • Apr 2011
                  • 160
                  So, I made mistake by deleting supplies data? :S ... Machine actualy started to work after reseting,so I guess machine is set to make 40000 with 1 toner,but it didnt reset after adding new toner,so I did it manualy in service mode...
                  I am not into konica minolta too much, sooo i may sound stupid..
                  • mrwho
                    Major Asshole!
                    • 4299
                    That 40k counter is not for the toner - the "supplies" part is meant for the Drum, Developer, Cleaning Blade, Charge Corona and Filter, all of those inside the Imaging Unit. There's actually no harm on reseting those, as long as you keep some record of when was the last time those were changed. The only one that shouldn't be run without actualy replacing the developer is the ATDC auto adjust - and there are some precautions to be taken when doing it.
                    Cheers!
                    Mascan42
                    Ibid
                    • Smiley27
                      • Apr 2011
                      • 160
                      Since no1 told me what ''developer'' is,now i learned, i used vacoom to remove it,and now i am doomed -.-'
                      Cheers!
                      • Smiley27
                        • Apr 2011
                        • 160
                        and now it gives me error C0F32 .. damn :S
                        • mrwho
                          Major Asshole!
                          • 4299
                          Mascan42
                          Ibid
                          • mrwho
                            Major Asshole!
                            • 4299
                            You'll need a new developer. And a Service Manual, so you won't screw things up again.
                            Or, better yet, call a technician - It would already be cheaper if you did it the first time around.
                            Mascan42
                            Ibid
                            • Smiley27
                              • Apr 2011
                              • 160
                              I removed developer from vacoom, filled it back, and copier made 3 copies !
                              and stoped again and gave me same error...drum made 60000,so i guess its time for new unit? ...
                              fail
                              Originally posted by mrwho;276
                              051
