Bh600+FS-604
  • blago_vd
    • 38
    Bh600+FS-604
    Hello,
    is it possible Bh600 to work properly with FS-604?
    If it is, then how?
    Thanks in advance.
  • mo0651
    • 1054
    Re: Bh600+FS-604
    Yes!......Place the bh600. then place a bh920 and plug the finisher in to the 920!
    • blago_vd
      • 38
      Re: Bh600+FS-604
      Thanks for the clever answer ...
      I'll explain the situation - an customer with working Bh600+FS-604 configuration wanted to upgrade the firmware. I installed V.31 mass production, taken from Infohub. After installing the firmware and restarting the machine, FS-604 can not make connection to the machine.
      Any suggestions?
      • Avskrap
        Partner in crime
        • Jul 2011
        • 160
        Re: Bh600+FS-604
        Are you sure the firmware update didn't fail some step? Try reloading it, I've had to do it 3-4 times on some machines, why I don't know... Also make sure the firmware supports the finisher - Some software don't, for some unknown reason.
        EDIT: Are you sure it's a FS-604? As the previous clever poster said, it's for the bizhub 920. FS-602 is the folding finisher for the 600, and FS-504/505 are the staple finishers.
        • mo0651
          • 1054
          Re: Bh600+FS-604
          Exactly!
          • blago_vd
            • 38
            Re: Bh600+FS-604
            Hello,
            I've installed the firmware several times, but only first time appeared "fnisher" in ISW board selection menu. After the first installation of the firmware the finisher "disappeared". I know that this finisher is for Bh920, but also this finisher somehow worked with Bh600. The bad thing is that the finisher acts like it has no power.
            • Avskrap
              Partner in crime
              • Jul 2011
              • 160
              Re: Bh600+FS-604
              My guess is that you had a fluke with it working to begin with and now that you've updated the firmware the machine doesn't recognize the finisher. Either downgrade to see if it works or get a proper finisher
