Jamming in fusing. But the fusing has the good condition of claw and hot roller. Sowat should i do? Thanks in advance
aficio 2018 jaming in fusing unit
Re: aficio 2018 jaming in fusing unit
Check the finger springs, they get stretched and paper will accordian in the fuser. The ends of the springs should be perfect circles.
These machines are great, if the paper actually makes it out of the tray without jamming (which is rare), it jams in the fuser, if for some unforseen act it makes it through the fuser it will most definatley jam in the 1 bin tray. And if the paper makes it completely out of the machine without jamming ( i've seen this once) the copies will be full of lines (unless the optics were cleaned yesterday). And we wont get into the fax send/recieve reliabilty (just go into fax sp mode and print out the service monitor report) -
You need to explain this better. Is the paper hitting an obstruction? Is the paper just left stopped in the fuser?I have not failed. I've just found 10,000 ways that won't work. ~Thomas EdisonComment
Common problem I have found on this issue the springs in the original machine are too weak and doubling the springs IE fit another spring on top of the other cures the problem this is unofficial mod, but works for me. Some will say that the hot roller fails more often due to wear on the surface teflon, but this can be cheaper than repeated calls for the same issue. This budget MFD usually I find is installed in a location where they also have cheap paper and poor storage conditions, ie portacabins etc where the temperature fluctuates during the night and the paper condition is poor. The paper is then liable to curl after passing through the UFR and LFR.Comment
