Pro C550 SC-45-01
  • draph
    • 132
    Pro C550 SC-45-01
    New customer and code continues after a good cleaning. Appears to be the color registration assembly. Any input or thoughts? Hate to hit a new client with such a hefty charge first time out. Thanks!
  • JustManuals
    • Jan 2006
    • 9838
    Re: Pro C550 SC-45-01
    Paul@justmanuals.com
    • The KM Man
      Check These Out
      C4501 at power up.
      Description:
      C4501.
      Solution:
      PROBABLE CAUSES:
      1. The PH unit has failed.
      Replace the PH unit (p/n A00J R741 00 and p/n A00H R700 00 for the bizhub C650).
      2. Failed power supply.
      Replace the DC power supply (p/n A00J M404 05).
      3. ICP6 on the PH relay board (REYB/PH) is open.
      Replace REYB/PH (p/n A00J H00A 02).
      4. ICP22 on the Printer control board (PRCB)is open.
      Replace the PRCB (p/n A00J H001 06).
      • draph
        • 132
        Sorry everyone. I screwed up. It's a 500 NOT a 550
        • mrwho
          Major Asshole!
          • 4299
          Check that all four colors are printing OK. Also check if the transfer belt is not traveling. All that assuming the reg sensors are working okay.
          Mascan42
          Ibid
          • The KM Man
            C500? Then Possibly this
            SC45-01.
            Description:
            SC45-01.
            Solution:
            CAUSE: PS8 has been checked and is good. Failed write unit (print head).
            SOLUTION: Replace the black (K) write unit (p/n 65AA -650 2E).
