Bizhub 200 250 350 print aborts until network cable unplugged
  • Tec1
    • Dec 2011
    • 48
    #16
    Re: Bizhub 200 250 350 print aborts until network cable unplugged
    also, try unchecking SNMP in port config.
    sorry, forgot to mention that in last post
    • kon
      • 55
      #17
      DHCP is being used when the machine is set to a fixedTCP/IP address.
      Set the machine for DHCP so it may acquire a TCP/IP address. Once the machine has a TCP/IP address assigned, it verifies the problem is with the
      setting. Reserve a TCP/IP address for the machine and then the machine can be set back to a fixed TCP/IP address.
      Note : This occurs when the Ethernet cable is plugged in. The machine works fine when the Ethernet cable is not plugged in.
      • Don N.
        • Nov 2011
        • 409
        #18
        Come on, man. Read! The copier's ip is static at every account we have, and outside of the dhcp pool range. THERE ARE CORRUPT PRINT JOBS IN COMMON WITH THIS PROBLEM AT EACH (DIFFERENT) CLIENT"S OFFICE. Delete the maps.google doc and it's fine.
        Sorry for yelling...
        • kon
          • 55
          #19
          You didn't like the last answer you won't like this one. Call support maybe they will care
          • Motormount
            • Sep 2010
            • 78
            #20
            Originally posted by Tec1
            have you tried using LPR insead of RAW in port config?
            Try Tec1's advice: change port from RAW to LPR with print queue of PRINT. This is a fix for the NEC IT3640D, similar model to bizhub 350 on Win 7.
            Also I have found almost any PDF printed from email attachment (especially sent from a MAC) without opening it first will cause 999a abort code.
