C-203 Fuser reset
  • Max Kilby
    • Oct 2011
    • 30
    C-203 Fuser reset
    Hi Folks.
    I seem to remember similar posts on here but I've done a search using model number and 'fuser' and so on, but had no joy finding the answer I need.
    We have a s/h C203 bought in by the boss ex-lease which we're refurbing - the fuser looks good and we like to reset them before putting them out but this one doesn't take a reset.
    Using the same pico fuse that Konica fit as original, didn't work. Tried another fuser from another machine with a new pico fuse. That didn't work. Tried a reset with a 50ma quick blow fuse - that didn't work.
    When we meter the fuses out, they haven't blown.
    I seem to remember seeing that if someone had tried a reset previously with a fuse that was too big it blows a board -
    Your words of wisdom please guys?
    Thanks,
    MAX
    Web: Welcome to Adelaide Copier Service and Supplies
    Mail: adelaidecopier@yahoo.com.au
  • mitchl
    • Apr 2007
    • 501
    Re: C-203 Fuser reset
    Look and see if you have any p codes showing and if so get rid of them and try again.
    • JustManuals
      • Jan 2006
      • 9838
      Paul@justmanuals.com
      • Max Kilby
        • Oct 2011
        • 30
        Hi - already thought about that one - certainly no evidence of a p code on the control panel.
        I tried refusing the belt and that reset OK which would negate that as a problem wouldn't it? I think it may be that someone had already tried and popped the main board - everything seems to work OK otherwise.
        I'm told there is a new version of firmware that allows the machine to work after the natural life of fuser/belt have been reached - any ideas?
        TIA
        • blaze2000
          • Sep 2010
          • 232
          Yeah check out Tech bulletin 7528 (12/19/11) should be what your looking for.
          • Mooseface2r
            • Jan 2011
            • 114
            Iv had it not reset when replacing the fuser with a new one, had to change the pcrb i think from memory.
            • Max Kilby
              • Oct 2011
              • 30
              Hi Chaps.
              The workaround seems to have fixed the problem for me.
              Thanks for your input.
              • Digit@lOffice
                Hi, I've replaced a fuser unit on a Olivetti d-color MF 201 plus (same machine), but the counter not reset... What I do?
