C-6501 error code C-C101
  • jrider
    • Jul 2025
    [Error Code] C-6501 error code C-C101
    * C-6501 with error code C-C101*
    ordered and replaced PRCB, ran adjustment mode ran about 30 great prints, then it threw error code C-C101 again. No warmup or anything just C101- tried replacing old board no go...
    ? any response would be greatly appreciated.
    (Communication abnormality)C-C101*
    When the sub power switch(SW2) is ON, no response is received from the printer control board (PRCB) within the specified time.Printer control board (PRCB)I/F board (IFB)Image memory control board(IMCB)Overall control board (OACB)
  • twinax
    • 82
    Re: C-6501 error code C-C101
    Hello,
    The error code C-C101 is software error.
    You installed a new PRCB, this one is delivered with a basic software in version 11, you need to upgrade your engine in lastest version (according to previous PRCB).
    Other PCB are normaly not involved.
    Check soft levels.
    Take care, if you change OACB the software upgrade of that one need to be downloaded with ISWtrns (Konica-Minolta tool)
    After that it will works.
    Regards.
    Remember Murphy's Law.
    • mr.propper
      • Sep 2009
      • 16
      hello,
      • jrider
        Thanks guys,
        props to mr.propper. Repaired shorted wires on drum carraige, installed repaired prcb, dc motor- thank you for the help!
        • empiru
          • Feb 2011
          • 229
          I just can't believe this!!! I service 5 C6500's and after having the same problem on one of them a few moths ago, I discovered that on other 2 machines that little plastic guide was also missing...
          Just saying, I think it's a good idea for anyone who services this type of machines to check this out...it could be some kind of a "design/construction flaw"?
          I don't help end-users. Hate me, give me bad reputation, I don't give a rat's a**. Pay a tehnician to solve your problem! We have to live too! What do you do when something hurts? Do you go to a doctor, or do you search it on google/ forums?
          • DanTheRicohMan
            I have the same problem. I was doing a PM on a CPP 650 and this error code pops up. I repaired the wire harness but still have C-C101 is it just the printer control board (PRCB) or do I need to order something else as well?
            • DanTheRicohMan
              Replacing the board fixed the problem! Since i only have 1 CPP650 I had some of the other techs in other areas check their M/Cs and half of them had the cover to that harness missing and the wires hanging!
