display bizhub C352
  • eugenionitza
    • Nov 2011
    • 18
    display bizhub C352
    Hi
    I have a KM bizhub C352and I just changed the touch screen but now
    I have a new problem with the display , it is not lit 100%
    the display is very dark, lighting level is almost 5%, but the brightness or contast buttons are not at fault
    Does anyone know what the problem is?
    Eugen
    eugenionitza@yahoo.com
  • blaze2000
    • Sep 2010
    • 232
    Re: display bizhub C352
    reseat the connectors on the display. Might want to check the corresponding connections on the circuit board as well.
    • eugenionitza
      • Nov 2011
      • 18
      I changed control panel with another control panel and the problem is as identical
      the cable is ok no damaged ...
      thanks
      Eugen
      • blaze2000
        • Sep 2010
        • 232
        Then you will want to check your input voltages to make sure you are getting the right voltages coming into the display.
        • JustManuals
          • Jan 2006
          • 9838
          Paul@justmanuals.com
          • MCBIG
            • Feb 2012
            • 36
            Check PJ5IPB pin 4 on the IPB for 24V. Also check PJ12IPB pin 24 for 24V. If the 24V is missing, replace the IPB PWB.
