energy saver C35P
  • mapel
    [Misc] energy saver C35P
    Does anybody know how to activate the energy saver function on a C35P-version. In the sys default menu i only see saving time. Energy saver has to be disabled.
    In our country is probaly forbidden to disable the energy saver function due to energy star label certification.
    I guess it goes bij softsw?(these are not communicated in the service manual...)
    The printer has the latest Fw.
  • Michelle W
    Re: energy saver C35P
    1. Press the Utility/Counter key.
    2.The Utility Mode screen will appear.
    3. Touch Meter Count on meter count display.
    4. Press the following keys in this order.
    Stop 0 0 Stop 0 1
    5. Touch Password, and enter the CE password using the display keyboard or the 10-key pad.
    Note92729272Soft Switch Setting.
    7. Change switch 6 to 1 (effective after power is cycled).
    8. Press YES then OK.
    9. Press the Reset button to return to the main screen.
    10. Power machine OFF/ON.
    Note: The setting will not be viewable in Admin Settings after setting the Soft Switch. To confirm that the change was made, print before-and-after configuration pages, and you will see that auto shut-off is now set to OFF.
