Bizhub c10 mfp: Fatal error code 2AH
  • Hansoon
    • Sep 2007
    • 3376
    That's what the book says:
    Fatal error code 2AH: Faulty memory data.
    1 - Unplug the power cord and plug it in, then turn OFF and ON the Power Switch.
    2 - Check Parameter Chip (PJ26) on PWB-A for proper connection and correct as necessary.
    3 - Change PWB-A. (8314139-0101-15)
    4 - Change Parameter Chip.
    Any other solutions than the above mentioned?
    Hans
  • MCBIG
    • Feb 2012
    • 36
    Re: Bizhub c10 mfp: Fatal error code 2AH
    I seem to recall that Konica Minolta will replace these machines (C10, 2490, 2480 etc...) if they get that error.... It may be worth a call. I think I'd just start with the 800 customer service line for end users.
