Bizhub C450 Finisher not recognised
  • Lazuli
    Printer Technician
    • Mar 2009
    • 21
    I was called to a Bizhub C450 with labels stuck on the transfer belt. I had to disconnect the finisher to get the transfer belt out, cleaned the labels off and them reconnected everything. Switched on and it prints fine but the finisher is not working. It is plugged in, and when you switch on there is a very quick sound of a motor in the finisher but it does not work. There are no error messages to refer to, it's just dead.
    I would be grateful for some pointers.
  • blaze2000
    • Sep 2010
    • 232
    Re: Bizhub C450 Finisher not recognised
    First thing I would check is to see if the mfp disabled the finisher in service mode, by verifying that it is in an 'UNSET' state. What finisher do you have?
    • Avskrap
      Partner in crime
      • Jul 2011
      • 160
      Check the connector in the horizontal transport, where the plug goes in. Poor quality of the fasteners and some glitchy connection can make it unable to get full contact with it. Also, the cables between the machine and finisher is sometimes very badly damaged from twisting and being in between the finisher and machine.
      • JustManuals
        • Jan 2006
        • 9838
        Paul@justmanuals.com
        • MCBIG
          • Feb 2012
          • 36
          Sounds like an issue with the horizontal transport. Check to see if the gears are mating properly at the rear of the finisher between the horizontal transport and the finisher. It can be easy to knock this out of place and everything on the top side still looks in place.
          • Lazuli
            Printer Technician
            • Mar 2009
            • 21
            The finisher is FS-507. The motor that momentarily operates at start up is the Punch Motor (M11-FN). The cables and connectors look OK subject to doing a pin to pin continuity test. There is a flashing red LED on the bottom of the Control Board (PWB-A FN). In service mode I can see all the sensors in the sensor check area and they are all at zero and don't change when activated. In the finisher area I can change the settings for punching and stapling so it seems that the finisher is seen by the main unit but there is still no error codes.
            The service manual, I got it for free, does not throw any light on this issue so any help will be useful. Thanks in advance.
            • Mita-Konica-Tech
              • Jul 2011
              • 76
              I've seen this type of problem before; try reinstalling the firmware on your machine... I've seen were a tech forgets to unplug the copier, before disconnecting accessories....!
              • Lazuli
                Printer Technician
                • Mar 2009
                • 21
                I thought that the firmware might be a problem but I understand that only KM techs can get the firmware. If you know where to get please let me know.
                • EarthKmTech
                  Step aside, noob
                  • May 2009
                  • 2139
                  I've seen hundreds of these old boxes over the years, mostly with finishers and I've never to date seen one that didn't know the finisher was installed.
                  I assume you turned the machine off at the main switch when unplugging the finisher ? (not the control panel sw, as that really does F/all electrically) unplugging the finisher with main power still on can and does have dire consequences on some machines. The finisher will only be detected after a cold boot, turning the machine off and on from the control panel will do stuff all.
                  the most common issues with these old finishers have been noted already, ie the horizontal transport unit not being plugged in (constant jam state referring to the said unit, as photo interrupters will be assumed to be blocked)
                  the other issue being the horizontal transport unit not being mounted properly in its poorly designed hook arrangement, this will simply cause jams at horizontal transport if the drive gear isn't meshing.
                  • Lazuli
                    Printer Technician
                    • Mar 2009
                    • 21
                    • EarthKmTech
                      Step aside, noob
                      • May 2009
                      • 2139
                      uh oh!
                      yeah that is a trouble reset procedure. what it fails to mention though is that you have to wait a while with utility pressed before trouble reset appears.
                      give it a try, you got nothing to loose.
                      I swear ive accidently unplugged finishers on this model while the machine was on and ready with only an error code being generated and all being fixed after turning the machine off at the main switch, plugging the finisher back in and turning it on.
                      if you open the finisher doors or move it away from the main body does the machine even know about it ? I assume the paper is feeding through it ok ? In what manner is it "dead" ?
                      there are 2 versions of finisher on this machine, a povo version that only side staples w/optional hole punch (or ultra povo that only corner staples) and the top of the range unit that booklet folds, saddle stitches and side staples w/optional hole punch. The better one is the same finisher used on various brands of machines over the years such as kyocera and canons (that I've seen, maybe more)
                      • Mita-Konica-Tech
                        • Jul 2011
                        • 76
                        Send me your email address and I will forward the firmware
