BIZHUB C352 touch screen light off
  • tecnomarco
    • Jul 2011
    • 203
    Good evening everyone, I have the following problem on a Minolta bizhub C352, I was turned off the light that illuminates inside the touch screen, this happened after I had dismantled the group keyboard, because I do not accept the commands that I was doing with fingers on the touch screen, i ask for a hint on what may have happened, and the flat pins are all connected, what can I do?
    heartfelt thanks
  • blaze2000
    • Sep 2010
    • 232
    Re: BIZHUB C352 touch screen light off
    Can you see anything on the display? Do you see the Konica Minolta logo, or the full touch screen? Does the screen work when touched?
    recheck all your connections, the backlight is not controlled by a ribbon/ flat cable.
    • tecnomarco
      • Jul 2011
      • 203
      [The logo appears and accepts commands normally, and everything works except that the backlight is absent.
      • Shadow
        PHD in Sh!t Disturbing
        • Sep 2011
        • 455
        unfortunately you are going to have to disassemble the operations panel again. check that the edge around the frame is clean, and that both sides of the touch screen are clean. also take care in resetting all the connectors. reassemble the panel and test to see if you have it fixed. I had this happen and this is exactly what I did to resolve the issue. some times all it takes is a little bit of something to make the back light not work.
        $hit Happens - Deal with it and move on.....................................sigpic....................................Lock & Load
        • tecnomarco
          • Jul 2011
          • 203
          I disassembled the whole group keyboard and cleaned all parts and rechecked all connections, but the problem persists or accept all touch controls, but the backlight is off
          • ineo+6501
            • Mar 2010
            • 262
            Sounds like you have blown the PWB which is below the metal casing in the scanner box. It is behind the CCD.
            This circuit board supplies voltage to the LCD screen. You'll need to replace it.
