Bizhub Pro 920
  • hosbiz
    • 13
    [Error Code] Bizhub Pro 920
    I'm having this Code SC 90 -01 on Bizhub 920.Check the ICP's on Main Board and ADU board and found them all OK. Checked also the voltages going to the ADU board -all are Ok. Any suggestions please.
  • blaze2000
    • Sep 2010
    • 232
    Re: Bizhub Pro 920
    If ADU is good, you may be looking at replacing PRCB.
    • O sentinela
      • 20
      Re: Bizhub Pro 920
      clean the memory ddr or charge de firmware!!
      • otomatic
        • Jun 2009
        • 26
        Re: Bizhub Pro 920
        got the 90-01 on one of our machines and swapped out the adu board and the code cleared but now the fuser will not light up and stuck on copier warming up
        if I put the old board back in and start the machine in tech rep the fuser works but nothing on the adu works I exit tech rep and it kicks the code again
        I did find a blown fuse on the old board and replaced it but still did not work
        is there some sort of reset I must do when changing these boards?
        I also have changed the printer control board to no avail
