konica minolta di 470 print controller error code 1808
  • brent
    • Nov 2008
    • 1214
    at least that is what I thought it said
    do I need to re seat the print controller
    to the machine again. or what is the
    problem. any thoughts?
    brent
  • JustManuals
    • Jan 2006
    • 9838
    Re: konica minolta di 470 print controller error code 1808
    Paul@justmanuals.com
    • Hansoon
      • Sep 2007
      • 3391
      Reseating the controller might help indeed and also:
      From the "Solutions" list:
      Solution ID TAUS0644762EN* Solution Usage 1
      Description
      Intermittent C1808 service code being indicated on the copier.
      Solution
      Cause:
      The Power Relay Wire for the Controller is improperly mounted. Because of this the relay wire has become pinched/trapped between the print controller
      assembly and the PWB-B circuit board causing the service code.
      Solution:
      Make sure the Power Relay Wire is routed correctly. It should be held in place by 10 wire saddles that run below the PWB-B and down the lower left corner of
      the copier. See the attached PDF file which outlines in detail the rout the harness should follow.
      Hans
      • brent
        • Nov 2008
        • 1214
        will give it a try. thanks
        brent
