PROBLEM When I turn on Konica 8050
  • cabello4783
    • Jun 2025
    Hi, When I turn on my konica 8050, give this mistake JC-32-12, The machine says there are paper jam,
    but there are not any paper in here. I think is a problem whith the sensor in zone 9. I tried press the sensor
    but all as usual.
    Anyone Know how can I defuse the sensor o Know other solution?
  • JustManuals
    • Jan 2006
    • 9838
    Re: PROBLEM When I turn on Konica 8050
    Paul@justmanuals.com
    • Coptech
      worker drone
      • 460
      Been awhile but I think there is a flip down jam removal plate just after the fusing rollers. There was a bulletin about re-routing the wiring because it would unplug the sensor when the plate was opened.
      At least that would be the first thing I would check if it shows a J-32 jam at power up.
      • RRodgers
        • Jun 2009
        • 1947
        Yep that's what it is. I usually just use a tie wrap to hold it in place. One thing, DO NOT PLUG THE CONNECTOR BACK IN WITH THE POWER ON!! You WILL blow the ADU board.
