How to access the imaging sensors PS7 and PS8 in the c6501 Konica Minolta
  • keranali
    • Apr 2012
    • 5
    Hello Everyone,
    I am trying to access the imaging sensors I believe they need cleaning, I am getting an error C4521 which states there maybe a faulty sensor in the imaging Correction Unit however I have no idea where they are located I have little experience with other Minolta's in the past and believe they are all similar. Anyone knows how to gain access to these sensors.
  • 907tec
    • 434
    Re: How to remove front cover in the c6501 Konica Minolta
    Now is the time for the obligatory "Don't-Play-With-6501's-Unless-You-REALLY-Know-What-You-Are-Doing" message. If you can't get the front door open, it is probably a sign that you shouldn't dig any deeper. No disrespect intended, just trying to save you from a potentially expensive mistake and/or downtime. Call someone who has experience taming these beasts, it is worth it.
    • keranali
      • Apr 2012
      • 5
      Re: How to access the imaging sensors PS7 and PS8 in the c6501 Konica Minolta
      OK will do thanks however do you know where the sensors are located ?
      • JustManuals
        • Jan 2006
        • 9838
        Paul@justmanuals.com
        • eifling
          • Apr 2011
          • 43
          Open the machine, slide out the section with transfer, look inside and on the left you will see a metal colored panel. On that panel are 3 spring loaded covers, gently lift each one up and gently wipe the sensor that is behind each one.
          And if you had a service contract with a tech, this is what he would tell you to do rather than making a trip to wipe a sensor because its pretty simple. If this doesnt fix it you have other problems.
          • keranali
            • Apr 2012
            • 5
            Thank you very much eifling I up again and running. Thanks Again
