paper coming out of fuser unit curling bad, replaced fuser rollers upper and lower and some of the feed rollers. has any one with same problens and found a cure. thanks in advance
minolta Di3510 copier paper curling .
MinoltaTech
Paper Curling upon exit
in many cases and reduce the curl/wrinkling.
Let me know if this helps.
DerikAttached Files -
I was thinking that maybe the machine had one of the early FN-117's which had you remove the 2 white rollers at install and if you ever took off the finisher the paper would curl due to the lack of the aforementioned white rollers!Comment
