Konica Minolta 7255 Fuser lamp does not shine
  • zxzabc888518
    • Aug 2025
    A friend from China, I am also a maintenance of copiers, very pleased and we met in this forum!I have a Konica Minolta 7255 copier, fuser lamp is not lit, but the fixing components is good, the fuser is installed in the other machine is normal, I replaced the power supply board, the main control panel, the imageboard, and carefully checked a bunch of lines on each machine, the problem is still there, always unable to find out where the problem!I hope you can help me, thank you!Thank you very much!
    My mailbox is zxzabc888518@gmail.com
  • JustManuals
    • Jan 2006
    • 9838
    Re: Konica Minolta 7255 Fuser lamp does not shine
    Paul@justmanuals.com
    • zxzabc888518
      Friends, servicemanual, butallI can not readEnglish!I totallyrely onGoogleinto thetranslation!
      Friends:Why did no onehelp me?Do wehavenotencounteredthis problem?
      • RRodgers
        • Jun 2009
        • 1947
        check the copier side socket for the fuser. Be sure that you don't have any popped fuses or circut breakers.
        • zxzabc888518
          Thank you very much for your help, I went to the fixing component exchange to try on someone else's machine, if it does not work, I had this machine for accessories sold!
          • zxzabc888518
            Firmware of the machine I re-upgraded, is still the same!I heard people say that software into the 25 mode switch will be able to solve this problem!
            • zxzabc888518
              Brothers and I do like you said, I checked the front door a few switches and sensors, and clean, the problem is still the same, so there is not a problem, the problem has not yet been resolved.But really thank you!
              , I entered three of the 25 mode of a software switch inside 3-0,3-1,3-2,3-3,3-4,3-5,3-6 3-7, behind the 0 to a 1, the machine is actually not the F35, F36, code?
