Counter reset???
+ More Options
Posts
  • Dinos
    • Jan 2008
    • 9
    Counter reset???
    Is there any body knows how to reset the main counter of a Konica 7272 ???
  • JustManuals
    • Jan 2006
    • 9838
    Just curious, why would you want to reset the main counter?
    • Dinos
      • Jan 2008
      • 9
      Originally posted by MinoltaTech
      1.Turn the Sub Power and Main Power switches OFF.
      2.Open the Front Door and pull out all paper trays, remove paper and push the paper trays back in. (THE FRONT DOORS MUST REMAIN OPEN DURING
      THE PROCEDURE.)
      3.Turn the Main Power and Sub Power switches ON.
      4.Press the [P] key for the counter display screen.
      5.Enter the appropriate engine password (894209) for counter reset.
      6.Press the [Proof Copy] key twice.
      7.Select the counter to rewrite [Total count], [Copier count], [Printer count], [Scanner count] and enter the desired value with the numeric keypads.
      8.Press the [START] key.The selected counter isrewritten.
      Note:The Total Counter Start Date cannot be changed.
      9.Press the [STOP] key.
      10.Turn the power switch OFF/ON to store the data.
      How can I select the countrer that i want to rewrite??? (step 7)
      • MinoltaTech
        Counter Reset
        i havent attemped this myself so i dont know off hand, sorry.
        • Dinos
          • Jan 2008
          • 9
          I buy, repair and sell used Konica copiers.
          • Luther
            • May 2006
            • 682
            I guess in Greece it is not illegal to turn meters back on copiers? Must be the same for cars,and to post that info in an open forum is not a good idea
            • JustManuals
              • Jan 2006
              • 9838
              Luther- There will always be some 'hero' to come along and post the information thinking he's doing the world a favor.
              So this guy in Greece is selling used copiers as new because some guy in the US decided to be a 'hero' (replace hero with other terms of your choice)
              • Copier_Guy
                • 543
                Cadillac Man??
                Or maybe, Semi-Used Cadillac Man!!
                • Dinos
                  • Jan 2008
                  • 9
                  I sell used copiers us used copiers, but some customers need to know that their machine has a low meter. This is all about.
                  • wagon
                    Village Idiot
                    • Dec 2006
                    • 654
                    A place I used to work at would reset the meters on REFURBISHED machines and modify the serial number (put an 'R' next to it). Makes the paperwork easy... Mind you, another joint used to zero meters on demo boxes and sell them as new... shifty...
                    If you are hitting your head up against a wall it always feels better when you stop.
                    • Copier_Guy
                      • 543
                      Yessiree Bob!!
                      That is very unethical and I believe, illegal here in the states Cadillac Man!
                      • sebama
                        counter reset konica 7272
                        Hi my name is sergio, my English is very basic.
                        The code change for the meter of konica 7272, I did not work for me, I have the latest version of firmware. What is my problem ?????
                        Thanks.
                        • wagon
                          Village Idiot
                          • Dec 2006
                          • 654
                          Originally posted by iMind
                          Only for Techs, remember safety always comes first
                          Remove the power cord.
                          Open the machine and solder a 3300uF coil together with a paper clip to the two 220v wires ATENTION blue and black remove the yellow green wire from the ground, close the machine, turn on the main switch, put on high voltage glaves, (available in any electrical store) and now connect the power cable to the wall outlet, thats all, meter reset forever.
                          *******Moderator please remove the above post*********
                          Please DO NOT do what is described. IT COULD KILL.
                          • iMind
                            Vacuum Cleaning Expert
                            • Mar 2008
                            • 1116
                            It was just a joke, even a greek can understand that, don´t you want to bye a zero K copier from him, new out of the box
                            • Zorikos69
                              • 9
                              dinos i suppose you cannot ask for that kind of help as there are some legal issues reffering to counter resetting...you could try pm...
                              Tsiou miou...
