hi guys,i have a minolta ep 2010 cspro which is giving an error code c00-00,the machine can do all the warming up process but if i press the start button it pushes the paper up to the drum section then an error comes on.does an 1 knws the problem plz help im stranded.
minlta error cde
Tags: None
Re: minlta error cde
hi...the manual says c0000:main drive motor failure to turn.defective M2.defective PWB-A.over loaded rolls\roller gears belti advise you also to check the drum cart & developing unit gears and pushingcheck the starter may it is cakedi wish you good luck -
Paul@justmanuals.comComment
heater unit drive motor is not workingComment
