I have an image problem that I cant figure what it is. I already change the IU's, Fusing Unit, Image transfer Belt and the problem stays equal. This problem is just on the cyan and magenta colors. I put next some images of this problem on the color imagens.The first is halftone at 60 magenta (note the lines that are in the test pattern, the background is the oder side of the page) The second image is halftone at 60 blue(here the sames lines)the third is a copy (here the same lines)and the last on is the original of the copyI think that I have all the info but if something is missing please tell me thanks a lot
konica minolta c450 image problem
Re: konica minolta c450 image problem
check the magnetic roller in developing unit and we may know feeding of the orientation of media.(landscape or portrait).
thanks. -
Looks to me that you have a residual image of the gradation pattern showing in the background.
Did you run gradations just before you printed these tests ?
If so I would be checking the earthing to transfer belt.
If not then you would appear to have a very strange problem in so much as the machine is producing a weak image of the gradation pattern in the background at the same time as it is copyingComment
Looks to me that you have a residual image of the gradation pattern showing in the background.Did you run gradations just before you printed these tests ?If so I would be checking the earthing to transfer belt.If not then you would appear to have a very strange problem in so much as the machine is producing a weak image of the gradation pattern in the background at the same time as it is copyingComment
dont forget that this units are new, the blue and magenta units. But can you explain me better what you want say with feeding orientation? thanksComment
"dont forget that this units are new, the blue and magenta units. But can you explain me better what you want say with feeding orientation? thanks"
I think he wants to know where the lead and trail edge are.
DarrenComment
it's are new? ok friend check imaging unit magnetic roller charging connection maybe it not give proper supply voltage for magnet rollerComment
Problem is only on cyan + magenta internal printouts from machine.correct?
Black and yellows are good so this rules out transfer roller and transfer belt.
You have replaced the image units and transfer belt.
Check image unit connections/hv connections for these units.
If these are ok,which is likely, then hv board should be swapped out as the next step.
Also might be no harm to upgrade firmware to rule out any ghosts in the machine
Best of luck.Comment
