c 360 default to print black only.
  • brent
    • Nov 2008
    • 1212
    I know there is a setting to (from the mfp screen) to make the machine only print black and white. unless you specify color. customer is afraid of everyone printing colors unneccesarily. does someone know that procedure. i have done it before. but can not remember now. thanks
    brent
  • mervyn
    • Jul 2011
    • 90
    Re: c 360 default to print black only.
    Utility key-user-copier and the third box down change to current. Set the machine to black before you do this.
    • emujo
      • Jun 2009
      • 3009
      "print" and "copy' are 2 different terms...
      To default to B&W copies...set color mode to B&W, get into Utility Mode, User Settings, Copier settings, Default settings and select current settings
      For Printing, you must go into the printers folder, right click and go to properties (printer properties for Win7), Printing preferances, Quality Tab, set color to grey scale, Apply. Emujo
      • brent
        • Nov 2008
        • 1212
        thanks gentlemen. I know print and copy are different. when they print. the machine should differentiate. if not that is ok. just wanted the machine to be defaulted to black all the time. to prohibit unneccesary color copies. (customer request) thanks again
        brent
        • emujo
          • Jun 2009
          • 3009
          brent
          OK maybe I didn't understand what you were asking...If you turn on user authentication, and/or account track, then you can go through the control panel and set the allowed outputs on the authorized users...ie no color copy/print/scan...but the users would not be able to modify this selection..I still sounds like you are asking how to default to B&W in for copy and print...Drivers are defaulted through the preferances screen (shared drivers would be defaulted through the Advanced/printing defaults tab)..I know of no setting through the MFP control panel that would allow you to do what you ask..If you find it please post..Emujo
          • brent
            • Nov 2008
            • 1212
            ive done this before. but did not know how to get to the screen. you do have to select black. then like mervyn said.. that way it is always on the current screen. which will be a black copy. even when you hit the reset. it will still be on black. thank you mervyn... and emujo
            • Darren King
              copiertech
              • 652
              This setting will default the machine to black copies. It will not "prohibit" colour copies. It also will not default printing to black.
              • brent
                • Nov 2008
                • 1212
                I never said it did. it will make black copies from the glass or doc feeder. unless you tell it you want color copies right? I know that it will still print color from the computers.
                brent
                • Darren King
                  copiertech
                  • 652
                  Yes
                  • brent
                    • Nov 2008
                    • 1212
                    that is how I am gonna go then. thanks for all your help
                    brent
                    • acusso1234
                      Tecnico
                      • Dec 2008
                      • 250
                      Another way is to use the MONO driver available on KM site...prints came out only in b&w
                      ... In the minute that you're thinking of giving up, think about why you lasted so long ...
                      • brent
                        • Nov 2008
                        • 1212
                        ya but If I did that. they would want to print color. I probably won't use a mono driver
                        but appreciate the info
                        brent
                        • JR2ALTA
                          • Feb 2010
                          • 2033
                          Where is this mono driver? recently had a client requesting one for a c353, I couldn't find it.
                          • acusso1234
                            Tecnico
                            • Dec 2008
                            • 250
                            I can't find it too, but i know that the C360 series driver works on C353 too...
                            Online Services - Document Information
