Wavy paper on last 4 inches
  • CopyQ
    • Aug 2025
    End User having problems with Ld-6500 putting a wave in the last 4 inches of 11 X 17, techs have spent hours in it, no luck. Brought out a used finisher and same thing. I think the issue has to be in fuser to form such a perminate wave. Now there talking about swapping the entire paper transfer/duplexing/exit unit with a used one, not sure I want these older parts on my machine. Have attached photo of a program we are working on. Right now I have to take the finisher off and run sheets flat. Then run them through my folder, hand collate and stitch. Once again I have to find out how to fix my machine. thank goodness this forum always has answers.
  • minoltaed
    • Aug 2009
    • 45
    Re: Wavy paper on last 4 inches
    Lower fusing roller.
    • acusso1234
      Tecnico
      • Dec 2008
      • 250
      Lower fusing roller breaked bushings ( I bet only the rear one)
      ... In the minute that you're thinking of giving up, think about why you lasted so long ...
      • HoonBoy
        • May 2011
        • 130
        Did they lower the fusing temperatures? Any difference in face up / face down output? Could also be the exit roller, straight after the fusing...
        • kyrenecopy
          • Apr 2012
          • 205
          If it only does it with the finisher on then it must be the finisher. Unless I misread/misunderstand what you are saying. If it only does it when the finisher is on it then I would suspect that the paper is slowing down in the finisher allowing it to be in the fuser too long.
          Testing 1-2-3, testing, testing. Is this thing on?
