BIZHUB C220
  • stedros
    • Oct 2011
    • 34
    [Error Code] BIZHUB C220
    i worked on a machine but every time they try to scan it brings an error code C-FA16 plz wat could be the problem and the possible solution guys. thanks,the machine is C220
  • Gaffers01
    • May 2011
    • 334
    Re: BIZHUB C220
    I had a similar error code CFA14 which was resolved in a Firmware update.
    I would sugest trying this first.
    • emujo
      • Jun 2009
      • 3009
      Re: BIZHUB C220
      If it has a fax installed, disable it through service mode, then pull both the fax and interface bd..had one caused by the MK 702..Emujo
