BizhubPRO C5500-C6501 and Oce CS550-655 - banding and uneven density
  • kronical
    Kronic Copier Ninja
    • Nov 2009
    • 230
    Hey guys,
    Just had this brought to my attention and thought I would share to make sure you all have the info.
    We have had a number of instances where the charge corona was not in the correct position within the housing of the charge unit, out of the box. This will cause banding in the color and/or uneven density front to back. The issues can be easily seen using test target 53 at a density of 100.
    Hope this saves you all some greif and aggrivation.
    K~
  • RRodgers
    • Jun 2009
    • 1947
    Re: BizhubPRO C5500-C6501 and Oce CS550-655 - banding and uneven density
    Originally posted by kronical
    Hey guys,
    [ATTACH=CONFIG]15805[/ATTACH][ATTACH=CONFIG]15804[/ATTACH]
    K~
    Thanks for posting pictures, and yes it's been a problem for a while now.
    • jrf
      • 142
      Thank you for info
      • acusso1234
        Tecnico
        • Dec 2008
        • 250
        Tx
        ... In the minute that you're thinking of giving up, think about why you lasted so long ...
