Bizhub 250/350 drum scracthed
  • brianho80
    • Sep 2009
    • 198
    Hi All,
    does anyone always face the problem drum scratched at the edge of drum which cause of toner leaking?
    I just replace drum and developer unit not long ago but after sometimes, return to check the machine, saw the drum scratched at edge, even though i doesn't effect the print out but it cause toner leak and the scratched part will getting bigger after a period.
    i believe it caused by the hinge at registration roller; does anyone often face this problem? and how to prevent it?
  • PeterG
    • Jul 2008
    • 177
    Re: Bizhub 250/350 drum scracthed
    Check out this thread.
    http://www.copytechnet.com/forums/ko...ing-drums.html
    You can fit a ds-roll kit available from KM
    • armstrong
      I think you should have to replace the drum, developing unit and developer too. Your machine might be overloaded.
      • ineo+6501
        • Mar 2010
        • 262
        You need to change the transfer roller on the door as well as the drum & dev.
        • sore
          • Dec 2011
          • 10
          11 - 4163529801 roll[ATTACH=CONFIG]15881[/ATTACH]
          if you change these rolls you solve the problem
          • Darren King
            copiertech
            • 652
            In my experience it really isn't the worn spacer rollers that cause the wear on the rear of the drum. It is the transfer roller. There is a white guide roller that wears and causes extra pressure to be applied to the drum surface.
            The worn spacer rollers do cause issues though and they should be replaced as well.
            Darren.
            • Tec1
              • Dec 2011
              • 48
              i just modify Di350 IU
              then drum, develper unit and developer are replaced all at once
              • SmellsHot
                Head Tech
                • 512
                Collars in Dev unit and white guides on transfer roller will do this. Make sure to replace both. You can tell when the transfer roller is the problem the white guides are grooved into....
                Everyone has the right to be stupid. Some people just abuse this privelage more than others
                • brent
                  • Nov 2008
                  • 1214
                  how much more money is the di 350 unit? I have read that you can put these in. but I thought they cost right at 299 bucks? outch
                  what kind of modifications are needed to install this?
                  brent
                  • Hansoon
                    • Sep 2007
                    • 3389
                    The ATDC sensor build in the image units of the previous series will NOT work with the Bizhub 200, 250, 350.
                    From KonicaMinolta Solutions:
                    "Solution ID TAUS0801978EN* Solution Usage 5
                    Description
                    C-2557 (C2557) after replacing a defective ATDC sensor.
                    Solution
                    CAUSE: The wrong ATDC sensor was used. The Di3510 series of machines ATDC sensor looks identical to the bizhub 350 series but they are different and
                    operate in a different voltage range.
                    SOLUTION: Please use the correct ATDC sensor (p/n 4040 6040 01)."
                    Hans
