c350 side door not latching
  • brent
    • Nov 2008
    • 1214
    so I noticed that the big right side door will not latch. the front one will. but the back one just wont. so subsequently there are a few jamming issues because of the latch not latching properly. was there a mod for this? I have looked a little but will go back and continue to search. thanks gents an gals
    brent
  • 907tec
    • 434
    Re: c350 side door not latching
    Haven't seen a mod for that latch, but I have had to replace several of them that get bent. Usually the metal rail that secures the two plastic latches gets bent. I've never tried, but I would guess that metal rail is compatible with other machines.
    • brent
      • Nov 2008
      • 1214
      ya I just tightened up the 2 latches that attatch to that rod. there is a lot of pressure there. I tried to reform a little bit. but I am going to order one. mabee... if km still has them. thanks
      • 907tec
        • 434
        If KM doesn't have it, send me a pm. I can pull one off a parts machine.
        • brent
          • Nov 2008
          • 1214
          thank you. you are very kind.
          I need to sit down and make an order later today or tomorrow morning
          thank you
          brent
          • TheOwl
            • Nov 2008
            • 1732
            We have replaced heaps of those latches as it is pretty common for them to break.
            Your on the right track with replacing the latches.
