Bizhub C452 PCL Driver rasterization errors
  • A.Shaferov
    • Sep 2025
    Problem: lines of garbage (dots and noise) around raster images (or raster effects) in not raster (vector, MS office, etc) documents.
    Looks like error in RIP.
    Printer: Konica Minolta Bizhub C452
    OS: Windows 7, 64 bit
    App: Any (CorelDRAW, Illustrator, MS Office, etc)
    Driver: C652Series PCL, ver 3.6.0.0
    Driver info in russian (sorry, cant translate):
    Сердечник : 2.04.28-1.29
    Вспомогательный : 1.0.0
    KPD : 800.900.I0RU0.200.B00
    ROM Version:
    Code:
    [COLOR=#000000][FONT=sans-serif][TABLE="class: data-table-noline"]
    [TR]
    [TD="class: td-indent1, align: left"]MFP Controller BOOT Program[/TD]
    [TD="align: left"]A0P00Y0-1E00-G00-02(00)[/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1, align: left"]MFP Controller SubSet[/TD]
    [TD="align: left"]A0P00Y0-1F00-G00-14(00)[/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1, align: left"]MFP Controller[/TD]
    [TD="align: left"]A0P00Y0-0100-G00-D1(00)[/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1, align: left"]Operation Panel Message Data[/TD]
    [TD="align: left"]A0P00Y0-8100-G00-D1-300[/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1, align: left"]Fax Board Controller1[/TD]
    [TD="align: left"][/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1, align: left"]Fax Board Controller2[/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1, align: left"]Scanner[/TD]
    [TD="align: left"]A0P00Y0-0023-G00-82[/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1, align: left"]Printer[/TD]
    [TD="align: left"]A0P00Y0-0050-G00-16[/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1, align: left"]ADF[/TD]
    [TD="align: left"]A0HT0Y0-0024-G00-04[/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1, align: left"]Finisher[/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1, align: left"]RU[/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1, align: left"]ZU[/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1, align: left"]Panel CPU[/TD]
    [TD="align: left"]A0P00Y0-8900-G01-01[/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1, align: left"]DSC1[/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1, align: left"]DSC2[/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1, align: left"]Loadable Device Driver[/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1, align: left"]SD[/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1, align: left"]Voice Data[/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1, align: left"]Movie Data[/TD]
    [TD="align: left"]A0P00Y0-A000-G00-04[/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1, align: left"]Dictionary Data[/TD]
    [TD="align: left"]A0ED0Y0-B000-G00-0000[/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1, align: left"]OCR Library[/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1, align: left"]MFP Controller System[/TD]
    [TD="align: left"]A0P00Y0-1000-G00-D1(00)[/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1, align: left"]MFP Controller Print Controller[/TD]
    [TD="align: left"]A0P00Y0-3000-G00-AH[/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1, align: left"]MFP Controller Print Controller Font[/TD]
    [TD="align: left"]A0P00Y0-3F00-G00-35[/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1, align: left"]MFP Controller Print Controller Demo Page[/TD]
    [TD="align: left"]A0P00Y0-3E00-G00-01[/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1, align: left"]MFP Controller MIO[/TD]
    [TD="align: left"]A0P00Y0-5000-G00-27(00)[/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1, align: left"]MFP Controller PSWC[/TD]
    [TD="align: left"]A0P00Y0-5100-G00-20(00)[/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1, align: left"]MFP Controller MIB IF[/TD]
    [TD="align: left"]A0P00Y0-5200-G00-10[/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1, align: left"]MFP Controller IPP IF[/TD]
    [TD="align: left"]A0P00Y0-5300-G00-10[/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1, align: left"]MFP Controller Outside Controller IF[/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1, align: left"]MFP Controller TCP/Socket[/TD]
    [TD="align: left"]A0P00Y0-6300-G00-21(00)[/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1, align: left"]MFP Controller OPEN API[/TD]
    [TD="align: left"]A0P00Y0-7000-G00-13(00)[/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1, align: left"]MFP Controller Operation Panel[/TD]
    [TD="align: left"]A0P00Y0-8000-G00-D1(00)[/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1, align: left"]MFP Controller CSRC Control Body[/TD]
    [TD="align: left"]A0P00Y0-8300-G00-02(00)[/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1, align: left"]MFP Controller PIC[/TD]
    [TD="align: left"]A0P00Y0-8200-G00-A1[/TD]
    [/TR]
    [/TABLE]
    [/FONT][/COLOR]
  • mo0651
    • 1054
    Re: Bizhub C452 PCL Driver rasterization errors
    Print out internal test pages and demo page. It really looks like something in the layers of the pictures.
    • emujo
      • Jun 2009
      • 3009
      Try selecting the "Print as Image" check box in the driver diaog box..Could also be a font issue if you're getting your graphics from the web...play around with the quality settings..ie try web instead of document..Emujo
      • TheOwl
        • Nov 2008
        • 1732
        Try using the Postscript driver and see if the problem is still there. There is also a feature in the PS driver that you can try turning off as well to see if it helps which is called Postscript Passthrough.
        I have seen something similar in the past where my customer was adding a JPEG to a Word document, but the JPEG had a transparent background which Word didn't like too much. While it looked good on the screen, it printed out like rubbish. The same can also be replicated if you click and drag pictures into MS Office documents.
        If you are printing from an Adobe product, again try the PS print driver and also what Emujo said with the 'Print as Image'.
        • A.Shaferov
          There are no problems with PS driver and test images, no garbage, no noise.
          But I dont wat to use PS, because it is darker than PCL.
