Di-450 with Pi-5501 embedded controller. Enable Copytrack
  • Hansoon
    • Sep 2007
    • 3385
    Di-450 with Pi-5501 embedded controller. Enable Copy Track.
    Cannot find in the manuals how to work with Copytrack for the printfunction.
    Copy Track for both copier and print function are enabled. For the copier it works OK with access code but when sending a print job it just disappears from the spooler without being printed and/or giving an indication that the access code has to be entered. The Job List button on the copier lights up indicating that a file has been send but that's it. Nothing happens after that.
    Any hints please?
    Hans
  • mo0651
    • 1054
    Re: Di-450 with Pi-5501 embedded controller. Enable Copytrack
    You enter the code in the printer driver preferences. There is a button for it in PCL driver.
