BizHub 750 - cleaning web not moving
  • b3p0
    • Feb 2012
    • 60
    I have a BH750 that the cleaning web on the Fuser is not moving. I've replaced the web because the old one had a hairline crack on the frame and we thought maybe binding was they issue from the crack allowing the frame to flex. After replacement, it still doesn't run. When i run the machine with the doors open, the little U shaped arm never kicks the lever on the cleaning web.
    Anyone ever replaced this, or have any insight ?
  • JustManuals
    • Jan 2006
    • 9838
    Re: BizHub 750 - cleaning web not moving
    Paul@justmanuals.com
    • 907tec
      • 434
      Does the web advance when you move the actuator by hand? If you click that little U-shaped arm about a thousand times, you should see the new web tightening up and then advancing. I've never had problems with the actuator itself, just with the web assemblies.
      • Mr Patonerhead
        reset the web counter in the service mode, also reset the pm counter to zero.
        • b3p0
          • Feb 2012
          • 60
          WINNER !!!
          Reset count, started clicking away. Doh!
          I owe you a beer ... or a job if you ever wanted to move to iowa. serious.
          http://www.copytechnet.com/forums/em...pids-iowa.html
