konica 1050e hv separation charger problem
  • copycorner
    • 30
    [Jamming] konica 1050e hv separation charger problem
    When starting the hv auto adjust the machine will only get to 3/8. The paper is rolled up going into the fuser assembly. Any suggestions?
    Just found a ground wire came loose from the HV power supply. Reconnected and now the HV auto adjust runs through 4/8 but at least the paper stopped jamming at the fuser roller entrance. Still can't get 8/8 out of the High Voltage Auto Adjust procedure. Any suggestions?
    Last edited by copycorner; 05-26-2012, 01:58 AM. Reason: Found loose ground wire to HV power supply
