Bizhub 363 scan to email error...kinda
  • Kidaver
    Ghoulscout
    • Apr 2011
    • 912
    I have a bizhub 363 with scan to email set up thru gmail. The emails go thru but if you go and look in the job history for sent emails I see "Deleted: Image Log Transfer failed" Only info I can find on this error has to do with ftp or WEBdav set ups. Anyone else come across this?
    "In a cruel and evil world, being cynical can allow you to get some entertainment out of it."
  • morpk
    • Oct 2010
    • 97
    Re: Bizhub 363 scan to email error...kinda
    can i ask what dose your SMTP setup look like ?
    • Kidaver
      Ghoulscout
      • Apr 2011
      • 912
      it's gmail set up. smtp.gmail.com at port 587 with the Start TLS on and authentication filled in is pretty much all I did.
      • delboy10
        • Jun 2010
        • 43
        I think the machine may be setup to log (keep a record of scan document) all scan documents to a server (FTP). You could check with the following steps:
        1, enter administrator mode
        2, select security settings
        and check if Image log transfer settings is On.
        Cheers,
        delboy
        • aleksander
          • 378
          You need SMTP server on the network.
          • morpk
            • Oct 2010
            • 97
            Why dose he need a SMTP server on the Network ? he has clearly showed that he is using gmail as the SMTP Server relay, as long as the device has internet access you can use an external mail server you don't need one on the local LAN.
            • emujo
              • Jun 2009
              • 3009
              Cheers,
              delboy
              Dellboy is probably the winner..although I can't imagine accidently turning this feature on, as it defaulted to off in the softswitches...Is this a used MFP?
              • Kidaver
                Ghoulscout
                • Apr 2011
                • 912
                No it is a brand new out of the box machine.
                • kronical
                  Kronic Copier Ninja
                  • Nov 2009
                  • 230
                  Turn off Star TLS and turn on SSL (direct from Google)
                  • speedtek
                    • Apr 2013
                    • 46
                    Was this ever resolved? I am getting this error now on a 423, and can't find anything pertaining to it online or on the KM database.
                    • Kidaver
                      Ghoulscout
                      • Apr 2011
                      • 912
                      I swapped the Start TLS with the SSL and don't believe I had this issue again...
                      • 907tec
                        • 438
                        Only had this problem once, and it was related to an email notification for fax receipt. Turn off that notification and the problem disappears.
