I had been working on the transfer unit fuse, which is accessible by opening the bypass tray. I needed to get a new fuse, so I closed the tray (lifted it up and latched it in the closed position). I came back with the new fuse and found that, although I pull up on the lever to the left of the bp tray, the tray is stuck on the right side and will not open.
What latch or hook is used to keep the right side in place? How iis it accessible? I could use a diagram of the internals of the tray latch mechanism if anyone might has that.
Any help is appreciated. Thanks!
Ross Parrent
Ross Parrent
