The Bizhub c450 Twain Scanner has worked good with Fiery X3e TY ,and from Network PC Photoshop could import the scanned image from the c450.
But when I had to separate the fiery(because couldn't be recognized) and set the controller to the Empron(set to Zero), in the Import menu /device section of Photoshop there is no MFP or machine names ,and When trying to Search and connect to device by IP address I get the message "Destination device is not supported".
Is this problem normal and photoshop can't connect to Bizhub c450 without Fiery ,or there must be some adjustments to fix it. How can I use Bizhub C450 Scanner From Network PC.
So if the Experts could help and give a solution ,would be appreciated.
