Bizhub 750
  • rasman67
    • Aug 2025
    Bizhub 750
    I have a bizhub 750 that loses network connection after a print job has been printed. when a second job is sent and it stays online it says "job done improperly" If anyone has a solution for this It would be appreaciated.
    Thanks in advanced
  • SmellsHot
    Head Tech
    • 512
    Re: Bizhub 750
    My first thought is to update firmware. If that doesn't fix it. I'm thinking corrupt files on CF card.....
    Everyone has the right to be stupid. Some people just abuse this privelage more than others
    • rasman67
      Re: Bizhub 750
      I just updated firmware to level 30 MFP and 32 on the controllers. What can be done for a corrupt file on the CF card.
      Thanks for your responce
      • kronical
        Kronic Copier Ninja
        • Nov 2009
        • 230
        Replace the cf card.
        • pepper38_cnd
          Field Service Manager
          • Aug 2005
          • 1075
          Re: Bizhub 750
          if the "job done improperly" message is showing up on the PC. Make sure the auto aquire function in the print driver is disabled (if it has it). This will cause the second job to fail whenever multiple jobs are sent from any of the newer MicroSoft Office products. If you just ignor the message the job will complete after about a minute, but most customers react as soon as they see the message and start rebooting the printer and generate a service call.
          Online Store is closed. Chip resetting is a thing of the past! Thank you to all my past customers.
          Now into Ip TV KODI Boxes
