where i can download bizhub c351 firmware
  • realmudd
    • Feb 2011
    • 12
    anyone have firmware for km bizhub c351
    plz send
    real.mudd@yahoo.com
  • JustManuals
    • Jan 2006
    • 9838
    Re: where i can download bizhub c351 firmware
    Why do you think you need firmware?
    • realmudd
      • Feb 2011
      • 12
      The unit is stuck on the hourglass screen. I can't get into the service mode or pagescope. Based on the symptoms and discussions with other techs I'm going to need to update the firmware.
      • Shadow
        PHD in Sh!t Disturbing
        • Sep 2011
        • 455
        what version of firmware is currently on the machine?
        what version of firmware are you looking for?
        $hit Happens - Deal with it and move on.....................................sigpic....................................Lock & Load
        • JustManuals
          • Jan 2006
          • 9838
          And what are you offering in return for the Firmware? I can get it, but it won't be free.
          Paul@justmanuals.com
          • realmudd
            • Feb 2011
            • 12
            Actually, I have no idea. The printer won't initialize and cannot be accessed via pagescope. I can't get the firmware version info anywhere. Any opinion or ideas would be greatly appreciated.
            • mrwho
              Major Asshole!
              • 4299
              Could be either the firmware or the nvram recovery software.
              Mascan42
              Ibid
              • Shadow
                • Sep 2011
                • 455
                in accordance to active solutions and experience, this is a corrupt firmware issue.
                reinstalling the firmware and following procedure should provide a 99% solution.
                the 1% margin is if it is indeed a corrupted NVRAM issue.
                • CompyTech
                  Super Tech
                  • Feb 2011
                  • 706
                  Yes. There is a NVRAM recovery procedure somewhere for that %1. Which I have done before. But it will basically lobotomize your machine. Take you back to before factory defaults, and you have to set up again. If that doesn't work its a call to KMBS for a new NVRAM.
                  • parsmehregan
                    • Jun 2012
                    • 97
                    Well,I just almost have the same problem with c450 and so far looking for it's firmware and the Fiery x3e ty.I've been directed to Infohub website but no result so far.so if you find it anywhere ,please let m know.I would do the same for you
                    .good luck
                    • JustManuals
                      • Jan 2006
                      • 9838
                      .good luck
                      I have access to it, but it won't be free.
                      Email me if interested. Paul@justmanuals.com
