Bizhub C253 Manual Side Door stuck
  • Ronniemc
    • Aug 2025
    I replaced the Image Transfer belt door didn't close as easily as normal and now it will not open I also get the code C-2152. Any help is appreciated
  • Shadow
    PHD in Sh!t Disturbing
    • Sep 2011
    • 455
    Re: Bizhub C253 Manual Side Door stuck
    the side door latch is hooked, you are going to have to do some dis-assembly to be able to unhook the latch.
    as for the transfer belt, you are going to have to reset it manually by turning the drive gear.
    you are going to need a good slim screwdriver to assist in unhooking the door latch.
    its going to fight you some, but it will disengage and allow you to open the side door.
    $hit Happens - Deal with it and move on.....................................sigpic....................................Lock & Load
    • mmru4real
      • Aug 2008
      • 67
      Have seen this a couple times, usually it's because the transfer belt was not all the way in or screwed down before the door was shut, it's not a lot of fun to get it open afterwards
      • EarthKmTech
        Step aside, noob
        • May 2009
        • 2139
        this is precisely what you don't want to accidentally do on a Friday afternoon last job before home time.
        • JustManuals
          • Jan 2006
          • 9838
          Paul@justmanuals.com
          • Zeldaman
            • Mar 2011
            • 946
            • leanoric
              • Jul 2017
              • 8
              Got same right-side door stuck problem. I too recently replaced my wife's Bizhub C253 transfer belt for older one, in a fault finding effort to determine why prints coming out blue. When I put the newer transfer belt back in machine, I thought it located correctly. But, when right-side door closed it wouldn't shut properly and became majorly stuck!!! Just wont open anymore on one side. Found this forum and took notes, but, would like to know how to access the right-side of the door to the transfer belt? Seems no way to access anything at that sie without major dis-assembling of machine. Can anyone advise where to 'poke' a slim screwdriver to release door instead kind of solution? (At moment, I'm in dog house with the missus, having 'broke' her printer in trying to help! )
              • Wargames
                Leanoric,
                Did you find any answer or did you succeed by yourself to open the right-side door ?
                Thanks.
                Wargames
                • leanoric
                  • Jul 2017
                  • 8
                  Yes, resolved by turning two motors on board on right hand side panel. More detail and photos in another post called jamming. Search in this forum for jamming door
