Firmware Imaging Toolkit vs Cygwin
Re: Firmware Imaging Toolkit vs Cygwin
I have never used Cygwin so I can't compare the two, but, the Firmware Imaging Toolkit is a snap to use. If you are a KonMin authorised tech you will find it on "mykonicaminolta.com". It is just a matter of downloading and installing. Then it is ready to use.
Hope this helps.
Darren -
Hope this helps.
DarrenComment
Are you using the regular Cygwin or the Konica Minolta mini-Cygwin? AFAIK the regular Cygwin isn't apropriate for the job.' "But the salesman said . . ." The salesman's an asshole!'
Mascan42
Ibid
I'm just an ex-tech lurking around and spreading disinformation!Comment
