konica 7115 wrench flashing
  • DOE
    • Mar 2010
    • 258
    we just got in a old konica 7115 and the wrench is flashing. we dont have a service manual but i figure it means its time for maintenance. could someone tell me how to stop wrench from flashing. thank you
  • DOE
    • Mar 2010
    • 258
    Re: konica 7115 wrench flashing
    the copier still works fine
    • kyrenecopy
      • Apr 2012
      • 205
      to reset PM counter : Hold down 0+8 together, turn on power switch, enter number (252), press (0) key, press ( enter) on screen, Shut down then turn machine on again.
      doing this will reset the counter to zero. the only way you will know when it needs a preventative maintenance is when your copies go to garbage. Then it gets real expensive to fix versus calling a technician now to look it over. Your choice.
      Testing 1-2-3, testing, testing. Is this thing on?
      • Max Kilby
        • Oct 2011
        • 30
        Generally with these machines all the main service items do tend to go at once too - dev crashes, drum and blade need replacing and normally all within a short while of each other.
        You can either reset and ignore for now if you have low volume, otherwise prepare for a largeish bill and if you want to procede with a 10 year old copier or take this opportunity to upgrade.
        • JustManuals
          • Jan 2006
          • 9838
          Paul@justmanuals.com
