C550 light/faded print or copy
  • ebm
    • Apr 2007
    • 183
    Aloha,
    Any tech(s) out there experience intermittent light/faded printing on this model? Customer keeps calling for light images and has samples of the problem. However, there is no problem when the tech arrives on site. One sample the customer had seems to indicate the problem is isolated to black. Only the black print seemed to be faded or light, while the colored boxes and logos in the job were fine. Also, P-9 and P-21 alert codes appear on the management list.
    Mahalo
  • mikeena
    field service supervisor
    • Mar 2007
    • 216
    oh konicaminolta what have you done. i remeber when getting a new image unit ment it was new. but seriously i would take a look in replacing the image unit. i have seen this on a 550\350\450 basically evrey color machine that uses imageunits. they keep going out way to early. this issue is common for me. i have had it happen about 5 times in the last 30 days. i put in new image unit and about 1 to 2 weeks later im back there for quality issues
    • laserman06
      Conservative in Exile
      • Dec 2007
      • 323
      P-9 is black image unit
      P-21 is color registration failure(caused by the light black or P-9)
      1. Question: Have you replaced the IU?
      2. Cleaned IDC sensors?
      Look in the service manual, page 600.
      Also section 18 of the service manual has a good process to troubleshoot image quality issues.
      I believe that it is most likely to be your black IU. Depending on the life counter Konica is warranting them.
      The family that prays together, stays together!
      Smile God created you and He doesn't make mistakes!
      Relax, God IS in control!
      Be still and know that I am God
      Ps 46:10
      • ebm
        • Apr 2007
        • 183
        Konichiwa
        Tech has done the basics, IU,sensors,etc. We have claimed warranty on many IU's from Konica. Thanks for all the input.
        Domo
        • mikeena
          • Mar 2007
          • 216
          try replacing the transfer belt. we had a similar issue but instead of black it was all colors had a issue and black was fine. once we replaced the belt the problem went away
          • ebm
            • Apr 2007
            • 183
            Hola,
            Mucho appreciation for all who posted replies. Will try them all. We have a Konica DSM coming and I am sure he will tell us to do the same things that have been mentioned in this forum.
            Gracias!
            • B0265
              • Jan 2007
              • 718
              We had a brand new C451 with light copies and had to replace the transfer roller.
              • Haroldbfix
                • 212
                Im in C550 school this week, and the instructor has put alot of emphasis on doing the "Intialization and Stablization" adjustment. Then run the "Gradtaion" adjustments.
                He seems to feel that this will reslove most CQ issues and related codes. Try it and see if this helps.
                • mik
                  • 20
                  hi,guys did anyone seen my post http://www.copytechnet.com/forums/ko...-printout.html
                  it is similar problem like on this c550,i changed all iu,cleaned all machine include idc sensors,ph unit,from inside.try with changing transfer belt and transfer roller and guess-nothing hapeend,the copy or prints is still much lighter on the top than the rest 3/4 copy?Please see post about bizhub-c451-uneven-top-copy-printout,there is much more about this problem.
                  • kristine
                    Re: C550 light/faded print or copy
                    I have a bizhub C654 that suddenly started making faded copies/prints. It is all the colors and black. What would cause them all to fade at the same time?
                    • tsbservice
                      Field tech
                      • 7855
                      The answer may be - Lack of trained service technician?!
                      But it's not limited here since you resurrected an 9 years old thread!
