C450 Corona cleaning
  • Smiley27
    • Apr 2011
    • 160
    Hi, I want to clean coronas on 4 drums, could any1 pass me part of SM that includes separation of drum? and also, i wonder , how to get transfer belt out?
  • RRodgers
    • Jun 2009
    • 1947
    Re: C450 Corona cleaning
    It's not in the manual because it's not ment to come apart. I've had (very little luck) of using a q-tip to clean the corona's but I wouldn't recommend it as you'll get the little pieces of cotton left on the scortron. Maybe try a lint free cleaning pad that you can get in there, would be my suggestion.
    Good luck
    • Smiley27
      • Apr 2011
      • 160
      Ye, I get it, but what could cause color mixing on copies, for example, if i print 10 papers with blue sign on it, on some papers it will be blue, on some green/blue, on some green etc...
      • Smiley27
        • Apr 2011
        • 160
        EDIT !
        How do I take transfer belt out for cleaning?
        • SmellsHot
          Head Tech
          • 512
          Open right side door....two screws. one on each side........
          Everyone has the right to be stupid. Some people just abuse this privelage more than others
          • mrwho
            Major Asshole!
            • 4299
            After that, open the left side door, take out the waste toner bottle and pull the transfer belt out.
            Mascan42
            Ibid
            • EarthKmTech
              Step aside, noob
              • May 2009
              • 2139
              Ive been tempted to insert compressed air into the slot under the coronas where the ozone is drawn out - may make a hell of a mess but i bet it would clean them good enough.
              i have dismantled and cleaned c250 imaging unit coronas when they were white banding at the edges (no developer loss) and couldn't be bothered going to get replacements. It does work but its alot of effort.
              • Smiley27
                • Apr 2011
                • 160
                ''Ive been tempted to insert compressed air into the slot under the coronas where the ozone is drawn out - may make a hell of a mess but i bet it would clean them good enough.''
                You mean secondary corona inside machine? ( not the one's on IU) , where exactly are they located,and how to reach them? ''under the coronas where the ozone is drawn out'', i dont understand this well, picture perhaps?
                • Smiley27
                  • Apr 2011
                  • 160
                  I did it , but it doesnt want to go out, also some white plastic fell down, and I cant get it back.. :O ..
                  There are 2 screws, one holding from front side, and one securing from inside side's..
                  • mrwho
                    Major Asshole!
                    • 4299
                    Yes, as SmellsHot said, you need to remove those screws. That's why I wrote "After that" following SmellsHot post.
                    Mascan42
                    Ibid
                    • Smiley27
                      • Apr 2011
                      • 160
                      May sound stupid, but on which side to pull? ... 4* screws are included
                      • Shadow
                        PHD in Sh!t Disturbing
                        • Sep 2011
                        • 455
                        pull from the left side of the machine.
                        There should only be 2 screws removed for the transfer belt.
                        if your having colour mixing issues, then start looking at drum / transfer belt cleaning units.
                        have you run the half tone colour tests to determine which unit is giving you the problem?
                        $hit Happens - Deal with it and move on.....................................sigpic....................................Lock & Load
                        • mrwho
                          Major Asshole!
                          • 4299
                          Just the two on the right side holding the belt in place, like so:
                          I should add that if you don't have a service manual (and I believe you don't or you wouldn't ask how to remove the belt) you should seriously consider getting one or getting professional help, as you mentioned earlier some broken plastic part and that could lead you to a more expensive repair than you had in the first place.
                          Mascan42
                          Ibid
                          • Smiley27
                            • Apr 2011
                            • 160
                            No, I havent, how do I run it?
                            • mrwho
                              Major Asshole!
                              • 4299
                              See what I mean?
                              Mascan42
                              Ibid
