scan bizhub 750
  • michael@fotcop
    • Apr 2011
    • 27
    scan bizhub 750
    How do I scan via SMB with bizhub750 windows7?
  • RRodgers
    • Jun 2009
    • 1947
    Re: scan bizhub 750
    I've found that if you scan to the public folder on a win7 64 bit box it's a piece of cake to get them to scan, if you try to make a folder and try to have it scan to that it's a HUGE pain in the butt. So I've been send them to the public share.
    • emujo
      • Jun 2009
      • 3009
      Re: scan bizhub 750
      a. DHCP must be OFF on the MFP.
      I'm intrested in why you state DHCP must be off???
      Although I can see the value in assisgning a static IP for printing (but DHCP when set up correctly works quite well), the MFP being in DHCP or static has no bearing on scanning back to a shared folder...Not slamming your advice, just wondering why you think this must be so...EMujo
      • Masterchief
        • Apr 2011
        • 280
        Re: scan bizhub 750
        Have you tried raeding the manual on this machine???
        Or have you got one
        sigpic
        • TheOwl
          • Nov 2008
          • 1732
          Re: scan bizhub 750
          Originally posted by alamsandhu
          e. Port 139 or port 445 (either can be used) must be open on the server
          This machine uses 139 as it still some what relies on NetBIOS over TCP/IP where as 445 does not require NetBIOS over TCP/IP.
          The biggest thing on any Konica Minolta is to make sure that the NTLM version is set to v1/v2:
          1. Utility / Counter
          2. Admin Settings
          3. Network Settings
          4. SMB Settings
          5. Client Settings
          6. Change NTLM version.
          The machines are set to NTLM v1 out of the box, but Windows Vista and up (including all versions of Active Directory from 2003) use NTLM v2.
