Touch screen on c6500
  • Dixie
    • Jun 2012
    • 11
    [Misc] Touch screen on c6500
    I would be grateful for any help to get the touch screen working on my 6500. I can print from the creo but I am unable to use the mc screen. Tried reboot many times, but still shows red ring around start button. No errors show and when a sheet is printed the 'start' goes green while printing then reverts to red. Is there a reset procedure on powering up?
  • ni311
    • May 2008
    • 658
    Re: Touch screen on c6500
    Are you in Copy / Scan mode or in Machine Tab / Job List?
    Konica Minolta Error Codes - Explanations and Solutions
    • Dixie
      • Jun 2012
      • 11
      The machine when powered up stays on main page in machine tab.
      Still able to print via creo but not able to use any functions on the touch screen at all.
      • ni311
        • May 2008
        • 658
        You can connect a network cable to the machine and emulate the touch screen on the computer. Just be careful to connect the network cable to the machine (on the body of the machine near data cable) and not to the controller. I guess you'll find more details in an user manual.
        Second, you might check the connection of the display, situated on the right side of the machine under a grey plastic cover near (guess what) data cable.
        • Dixie
          • Jun 2012
          • 11
          Thanks for the reply,
          I have checked all the connections including the monitor end. Still no different and red light on start button. Will try connecting a pc (running on xp) to the mc network.
          Could it be a bad calibration issue? Have gone into calibrate screen, touched the screen prompts but no buzzer sound even on the test buttons.
          • ni311
            • May 2008
            • 658
            You have to understand that you won't be able to get a green/blue start button unless you are in copy or scan tab. It is normal to get the red button in machine tab.
            • Dixie
              • Jun 2012
              • 11
              I understand red is normal, the problem is the touch screen is not responsive at all. You can not even change the paper settings. If you try to go into copy you are unable.
              • dagoof
                Still learning...
                • 221
                I'm having this exact problem and was wondering if you were able to fix it Dixie (or anyone else can help)?
                In the past, I've had an issue with the calibration being out of wack, but the screen is still responsive to recalibration. Now, I get no beep/no response when touching the screen. I've got a 45-20 I'm not able to address because I can't get access to the screen
