Bizhub 750 toner leaking n too solid
  • brianho80
    • Sep 2009
    • 198
    Hi, does anyone know why this model always toner drop on T/S block and Mylar at drum unit full of toner.
    I had tried to vacuum thoroughly the Mylar n path connect to filter behind machine, drum units etc..
    Run this drum peculiar mode and even adjust max density adj = 19
    But some how max density will change to 39 after exit to normal mode.
    Anyone have other way to solve this problem?
  • ineo+6501
    • Mar 2010
    • 262
    Re: Bizhub 750 toner leaking n too solid
    This is a very well known problem on this model and there are many threads on this subject already.
    If the waste section of the drum unit is full, this is usually a sign that the solenoid which drives the coils has failed, replace it.
    As for the other causes, a simple search on this website will reveal all of the common fixes.
    • fixthecopier
      ALIEN OVERLORD
      • 4714
      I don't know without my notebook, but their is a solution that has you change 2 dip switch settings that will reduce the amount of toner used. Also make sure your grid voltage is correct, especially if you use aftermarket drums.
      • ni311
        • May 2008
        • 658
        This thread might help you:
        http://www.copytechnet.com/forums/ko...-solution.html
        Konica Minolta Error Codes - Explanations and Solutions
