Km Bizhub C-203 "Staple cannot be used currently"
  • Gabriel
    • Jun 2006
    • 141
    Konica Minolta Bizhub C203
    Machine is working just fine, Copy quality is excellent.
    The only complaint is the message "Staple cannot be used currently"
    because isn't a finisher connected to the copier.
    I cleared the trouble codes in service mode
    I did an initialization in service mode.
    No luck clearing the message.
    Any help is welcome
    Best Regards
    Gabriel
  • EarthKmTech
    Step aside, noob
    • May 2009
    • 2139
    Re: Km Bizhub C-203 "Staple cannot be used currently"
    in service mode, under trouble isolation, make sure staple is not selected.
    turning off and on the machine at the main switch should reset an error like that, if your getting a recurring error code for an accessory that isn't there you may have a failing printer control board.
    • Gabriel
      • Jun 2006
      • 141
      EarthKmTech
      Thanks for your fast response
      Is there any other test I can do before replacing the print control board?
      Best Regards
      Gabriel
      • EarthKmTech
        Step aside, noob
        • May 2009
        • 2139
        Originally posted by Gabriel
        EarthKmTech
        Best Regards
        Gabriel
        if staple is not selected under trouble isolation, its what i would try - however, i can return boards that were not required. If your situation is different you should call km technical support, it may be an nvram issue or something silly like that..
        • SmellsHot
          Head Tech
          • 512
          did you open/close front door? Cycle MAIN power? did you actually check out the stapling unit? does it move freely? That message should reset with a main power cycle so I'd look into the stapling section
          Everyone has the right to be stupid. Some people just abuse this privelage more than others
          • Gabriel
            • Jun 2006
            • 141
            SmellsHot
            That's the problem, No finisher attached to the machine
            and staple is not selected under trouble isolation.
            I'm running out of ideas,
            Any input is welcome
            Best Regards
            Gabriel
            PS: I'm waiting for the printer control board
