Konica Bizhub C350 C0096 Error
  • Doug James
    • Jan 2012
    • 935
    Before I start shotgunning parts, Knda think it has something to do with the transfer motor not turning on. Is their a fuse associated with this by any chance. When you turn the machine on the code pops up before initial rotation which kinda makes me think it is a controller board.
  • JustManuals
    • Jan 2006
    • 9838
    Re: Konica Bizhub C350 C0096 Error
    Paul@justmanuals.com
    • b3p0
      • Feb 2012
      • 60
      C350 does have a fuse on the transfer belt. It resets the counter for that part.
      • EarthKmTech
        Step aside, noob
        • May 2009
        • 2139
        comming up instantly just means you havent reset it properly;
        turning off and on the machine is NOT the reset method, open and close the front door.
        C0096:
        The 1st Image Transfer Retraction Position Sensor is
        not activated (retracted position) within 5 sec. after the
        1st Image Transfer Pressure/Retraction Motor has
        started turning during a sequence of the Transfer
        Belt's retracting motion.
        • The 1st Image Transfer Retraction Position Sensor is
        not deactivated (pressed position) within 1 sec. after
        the 1st Image Transfer Pressure/Retraction Motor has
        Belt's pressing motion
        usually its a case of a crappy old belt whose pressure retraction cams no longer move freely, I have cleaned and lubricated them in the past with great success, or you can just throw the belt away and replace it with a new one.
        • Doug James
          • Jan 2012
          • 935
          Thanks so much... Turned out (I believe that I haven't reset the code) probably is all right. I have alot to learn about Konica's. I better because I seem to be getting alot of them lately and I am not sure why. But I sure do appreciate your post.
          • minimerlin
            • 851
            Give the detection sensor on the back wall behind he transfer belt a blast with air..gets forgotten about all the time!
            Please do not PM me without asking first.
            • baderten
              • 38
              The problem has not been resolved or not
              Also I did not know where the m11 engine was
