Konica Minolta DI3510
  • CCS@yahoo
    • Mar 2009
    • 14
    [Electrical] Konica Minolta DI3510
    customer has DI3510, stays in warm up screen ( illustrations of 4 or 5 copiers ). attempted reboot, trouble reset; occasionally system goes to ready and becomes operational - 10% operational, 90% inoperational. Eventualy goes back to 'initial start up' screen and freezes up. Used as their printer - possible computer system issue ? Could use some help with this one
  • solis557
    • Dec 2010
    • 53
    Re: Konica Minolta DI3510
    I would remove the network cable from the device and see if the machine goes to the ready state. I had one where the nic went bad and would make the machine reboot, but once i disconnected the network cable it would copy fine.
    • BR549
      • 110
      Try disconnecting HDD. I had the same problem and that is what it was.
      • JustManuals
        • Jan 2006
        • 9838
        Paul@justmanuals.com
        • RRodgers
          • Jun 2009
          • 1947
          Check power as well, also might need a flash.
          • ck1
            • 485
            try remove the NC4 scan unit card and see. if still error rewrite firmware .
