konica c652 has bad data on print only like the wrong driver is being used any ideas
  • briang
    • May 2011
    • 2
    have put new fw and new driver and re intialized the machine
  • habik
    • 2013
    Re: konica c652 has bad data on print only like the wrong driver is being used any id
    how about screen shot? or
    Which of these can you print out and how they look?
    1,PCL font list
    2,PS font lists
    3,test page
    4,demo
    ? List output from service ? if you have all scan it and post it here with also scanned failed print.
    can you print the same doc on a different machine? how about different computer?
    suspecting MFP Board ..
    ...Good Luck
    Firmwares HERE
    • TheOwl
      • Nov 2008
      • 1732
      I would look at the following:
      1. Formatting the HDD (you will need to reload animation data and one-touches)
      2. Doing a RAM test
      3. Use a different driver. If you are using the PCL driver, try the PS or XPS drivers.
      • Chameleon
        • Nov 2011
        • 200
        I'll second the RAM test. and add replacing the patch cable.
        The chance that higher life forms might have emerged in this way is comparable to the chance that a tornado sweeping through a junkyard might assemble a Boeing 747 from the materials therein. -Fred Hoyle
